Skip to main content
ForestPack 9.3 - Highlights for Artists
ForestPack 9.3 introduces new creative controls for ForestIvy and ForestScatter that make vegetation workflows faster, more natural, and easier to art-direct.
At a glance
  • ForestIvy: Wind animation with global and per-component controls.
  • ForestIvy: Tapered branches and branch rotation for believable growth.
  • ForestIvy: Extend baselines by painting, no redraws.
  • Scatter: Grayscale-driven distribution maps for natural variation.
  • Scatter: Random scale by Area for local control in a single object.
  • Scatter: Faster viewport area painting with keyboard shortcuts.
  • Scatter Several Stability and performance improvements.
ForestIvy
Wind animation
ForestIvy branch and leaf animation Animated branches and leaves
Add motion to climbing plants without rigging.
  • A master switch enables the system across the entire plant.
  • Strength defines global influence.
  • Loop (frames) controls playback rate.
  • Branches and leaves can be adjusted independently for more nuanced effects.
  • A toggle in the Display rollout allows animation preview directly in the viewport. It is off by default for responsive editing, but can be enabled for setup.
This makes it easy to keep stems calm and let foliage flutter for a realistic breeze.
Tapered branches
Tapered Branches Tapered Branches
Branches can narrow toward their tips instead of staying uniform. In the Branches rollout:
  • Set Min Width and Max Width
  • Adjust Scale Range to define taper distance
Branch rotation
Use the new Branch Rotation parameter in the Growth rollout to rotate offshoots around the main stem, breaking up repetitive patterns on vertical surfaces.
Extending the baselines Extend baselines by drawing near the end
Continue growing ivy without starting over. Enable Paint, click near the end of an existing baseline, and carry on painting.
Forest Scatter
Distribution maps using grayscale Distribution maps using grayscale
Distribution images can now be interpreted as density maps instead of simple masks.
  • White = maximum density
  • Black = minimum density
  • Grayscale values = smooth interpolation
Enable Use as Density Map to activate this mode.
Each Area can define its own scale range.
  • Found in Areas → Scale Min/Max
  • Apply variation near paths, edges, or falloffs
  • Keep everything in one ForestPack object
Faster paint/erase
Hold Ctrl to paint and Alt to erase in Paint Areas. No need to switch tools in the modify panel.
Other fixes
  • Corona Interactive Rendering avoids unnecessary rebuilds
  • More stable collision checks for large distributions
  • Include/Exclude falloffs no longer interfere
  • Preset libraries with empty geometry layers now load properly
